1 - 17 of 17 Posts
hi im new to the forum, i just got a 64 monza jr. 160. it came pretty much bare, all i have is the frame, forks, swing arm, rims with the brakes and thats it. any help on where to get parts, what should i go about doing first, i guess and so on. any help would be greatly appreciated thanks. :)
Welcome. This forum is a great source of information. Check the recent threads; there are several 160 and Monza projects going on. Your best bet would be talking to those guys. Also join the bevelheads list on-line, as they are by far the best source of the information on old Ducatis. Good luck. Dan
+1 on the advice already given. As for where to start, figure out what you want to end up with. That will give you a basis to figure out what it's going to cost and what sort of parts you want to look for.
A lot of parts interchange in that era so putting something together isn't a problem. The problem often occurs when people figure out how much it's going to cost to get where they want to end up.
There are PARTS that interchange, not bikes. A lot of parts off a 250 Monza will "fit", a lot of other things won't. And those parts that fit may require a few tweaks here and there to make work. For instance, you can bolt on the frotn end from a 250 but you need a spacer on the steering stem.
It's been a long time since I looked at the foks on a 160 but I'm pretty sure the top cap on the slider screws off if you have a wrench to fit the little indentations? You've already gotten the spring covers off I'm guessing? They screw on the sliders also.
I have no iodea where you're going to find the seals to put them back tgether with btw. Maybe Guzzino or Domiracer has them?
does anyone know if the sliders come out of the front forks? it seems to be know way to take them out. there not built like the 250's or any normal fork.
It's been a while but as I recall, using a length of rod (like allthread from ACE Hardware) and making a slot in one end with a hacksaw and a 90 deg. bend as a handle for torque, you can reach into the tube with a mini flash light and unthread the slider, freeing it up for removal
1 - 17 of 17 Posts
