So what is the verdict on the use of a spacer on the rear wheel? The wheels I want to use are only available in 6".
thanks a lot for your advice.
John
I hear airplanes
Bump. Just found out I've got the same problem on my bike. I called Motowheels, waiting on a call back. 2mm or 5mm is what they were saying.
John
Should be no problem, just make sure the wheel is centered in the swing arm or is lined up correctly sprocket to sprocket.
