1 - 12 of 12 Posts
Can someone please post a pic of their 54mm full exhaust on a non-deep sump motor? I am looking for a picture of the loop at the bottom. As some of you may know from the struggles I had fitting a track-body work to my 749 with full exhaust. I decided to skip a few track days and buy the shark skinz, which supposedly fit the full exhaust. Tried fitting them last night, and it's a no go. The loop at the bottom is not clearing the belly pan. This makes me think if my full-exhaust installation is messed up. :eek::mad::confused:
solved
Plug in your air compressor and attach the small air sawzall. Cut the area around the pipe to fit. Done!
THank you thank you I know...
I dremelled a piece in the back. But cutting a piece in the bottom of the belly pan defeats the purpose of Belly-pan.. of course that would be my last resort :( I am just wondering why it doesn't fit my bike, when it fits every other full-ex bikes.
i had a 54mm termi full system on my 03 749 and had to trim away a section at the rear of the belly pan just in front of the rear tire.
Was it at the bottom of the belly pan or just the vertical piece in the rear?
I installed a full 57mm termi kit on my 749. If you want pics or advice pm me your email...
They are talking about trimming on the piece that is vertical, not the bottom of the belly pan.
I have some carbon and fiberglass here as well as the resins. If you want we can cut your belly up and then reshape it.
Discussion Starter #10
Well, I banged on the exhaust pipes with a mallet for a little while, and belly pan barely fits now. The pipes touch the bottom part, but I am done giving a shit about it. I just started the engine and let the exhaust pipes mold the fairings around them :D
Chris- That sounds like good plan. I didn't know that I could reshape fairings.. I will keep that in mind for the next set.
I made new fairing brackets out of aluminum that pushed the bottom of the fairing out a little further . Was still on when I sold it and no melting.
the long horizontal pipe was rubbing against the bellypan, so the bodywork was spaced with a hose clamp, screw and rubber stopper.
1 - 12 of 12 Posts
