So I know the stock pipes on my '02 748 are 45mm but is there a way to get a 54mm slip-on to work?
M mrodey · Registered Joined May 4, 2009 · 78 Posts Discussion Starter • #1 • Jun 15, 2009 So I know the stock pipes on my '02 748 are 45mm but is there a way to get a 54mm slip-on to work?
DukeDesmo · Registered Joined Mar 9, 2005 · 5,138 Posts #2 • Jun 15, 2009 Big exhausts on Desmoquattros will cost you power (or at least torque) it may fit but the bike will be slower for it. If you tune the bike you may need a larger pipe but I doubt you'd ever need a 54mm on a 748...
3 32698 · Banned Joined Apr 16, 2009 · 3 Posts #3 • Jun 15, 2009 You will lose power on the low end and torque, probably will have to go with bigger throttle bodies too which may be pricey. 54mm or 58mm
amullo · Super Moderator Joined Oct 15, 2004 · 8,217 Posts #4 • Jun 16, 2009 You can have a machine or welding shop maybe remake your x-vioer pipe to get 54mm cans to fit.. BUT as said above.. It´ll cost you power and torque (IE: Less power, not more). I´d sell them and buy 45mm slipons instead. //amullo
