Ill keeep that in mind, though $325 seems a bit steep for what youre getting. Is there a cat inside or is it just a pipe with bends and some mounting areas?Here you are fellow Matrix owner! It's not the Termi mid-pipe, but it should work all the same.
Arrow Mid-pipe
Yes, I agree it is a bit pricey. There are no cats or pre-mufflers, but there is an x-pipe crossover as well as the mounting points. But there is supposed to be a significant weight difference between the stock piece and the Arrow mid-pipe.Ill keeep that in mind, though $325 seems a bit steep for what youre getting. Is there a cat inside or is it just a pipe with bends and some mounting areas?
Is Ducman still in business? I called to verify their inventory on the Arrow mid-pipe and got a disconnected number.Here you are fellow Matrix owner! It's not the Termi mid-pipe, but it should work all the same.
Arrow Mid-pipe
Have you tried emailing Ducman? Also you might want to contact motowheels and see if they have something similar available.Anyone know? Hate to be stuck with a $900 set of useless exhaust.
