1 - 11 of 11 Posts
With the OZ wheels it should be a simple job... except they were especially made for the use of SC standard brakes...
disc spacing is 132mm on SC bikes... so 4mm more on each side compared to a Monster or ST front wheel
Discacciati makes 4p calipers for SC wheel disc spacing...
Discacciati’s are really nice but they’re at least $1k. Is there a way to make the brembo’s fit?
The OZ Piega wheels I bought 7 years ago, and still have on, came with spacers to put under the rotors. So perhaps it's as simple as leaving out the spacers --but check with someone who has tried it!
That's what i meant... just inspect the hubs and maybe just remove a spacer... or change the hub flanges... :smile2:
OZ wheels for the SC are made for 4P4P style calipers, the spacers that come with them are to fit the stock 2P Calipers.
I mounted the 4P Calipers along with the Piega wheels, using Brembo Thinline rotors instead of the stock rotors. The spacers are somewhere in my garage... For proper fitment, you should invest in some custom brake lines. The stock ones will work but there's a weird bend at the caliper.
Discussion Starter · #9 ·
Looks awesome! I'm in the process of getting beefier rotors Brembo 'snowflake' rotors. I hope I have the correct spacers but if I don't where could I get them from? I'm also looking into custom spiegler lines but I'm unsure of the length I'll be needing.
Cheers,
Mike
If you purchase rotors with the same offset as the stock ones (can't offhand recall what that is), then the 4P calipers + SC OZ Piega wheels all line up without spacers. The stock wire wheel hub is a bit wider than the OZ hub, which lines up with the 2P calipers.
Spiegler made brake lines to my spec. There's a couple of different ways to route brake hoses; the superbikes use a single line with a crossover between calipers. I tried to mimic the stock arrangement. The Spiegler website has a pretty simple ordering process, I think I just used a piece of twine to establish the needed lengths.
Your stock master cylinder will work with the 4P calipers, but be aware that you are changing the Master Cylinder/Caliper hydraulic ratio by adding 4 more pistons. The "feel" will be a bit different as the stock SC Master is smaller that what you'd find on a 999 or 998S. I just changed the master to a 999 unit, so mine is all stock Ducati in setup.
Discussion Starter · #11 ·
I just bought a pair of used but in great condition 'snowflake' rotors, brand new tires, and installed an rcs19 brake master cylinder. I'm really hoping that the OZ's and the rotors play nice without having to modify anything. The only thing left to get is the 4pad calipers and lines. I'm having a tough time locating decent looking calipers. I may just buy them brand new and that's that.
How much did you have to pay for your Spiegler lines?
1 - 11 of 11 Posts
