JohnBoy said:AFAM, Renthal, Sprocket Specialists and ESJOT don't make a 44t rear sprocket in steel for the ST's.
Anyone know who does?
You did not state which ST model you have. I use a 42T rear sprocket on my 04-ST4s and it works great at cruising around 4,000-4,500 rpm in 6th gear at freeway speeds or 4,000 rpm in 1st gear at 25-30 mph in town.JohnBoy said:AFAM, Renthal, Sprocket Specialists and ESJOT don't make a 44t rear sprocket in steel for the ST's.
I had 14/41 on my 01-ST4 which worked out well.JohnBoy said:I have an '01 ST2 which was stock at 15/42. This was quite a bit too tall (as are most all of the stock ratios).
