141 - 160 of 171 Posts
You are all good to go if you have a 1260.
The 1260 stock chain is 114. Consequently, a 120 links is the safe way to go but you'll need to shorten it.
However, the stock chain on a 1200 is 108. Thus I believe a 110 links will suffice to fit a 42T sprocket.
Other 1200 riders should chime-in to confirm.
I have a 2016 1200s. gotta make a bit more research then :)
thanks man !
@efixe
You will love 15/42 at all speeds; low, med and high. Guaranteed.
Well damn, I ordered my kit from SprocketCenter and 42T was out until 7/1. Now their site says mid-July which is annoying, especially as my old chain is shot.
Has anyone gone down to a 525 chain instead of the stock 530?
Don't go to a weaker chain width. It will just wear faster. Stick with a 530 chain and sprockets.
You can always buy the parts separately from different sources. I did.
For the 42T / 530 sprockets:
Here's for a kit:
https://www.carpimoto.it/en-US/Bike_Ducati_Multistrada-1200-S-16-/46592_DU-1252S-2-DID-530ZVM-X-Chain-15.htm
Here's another 42T steel sprocket:
https://motowheels.com/i-20552374-superlite-530-pitch-direct-replacement-steel-rear-sprocket-multistrada-1200-replaceable-outer-sprocket.html
530 / 110 chains are available everywhere.
Here's for a kit:
Thanks.
I looked at Carpimoto already and like the prices but not sure I’m up for a gold/gold chain, maybe if my bike was white but it’s red and I’m not really into bling
I’ll see what other package I can put together.
dumb question, but do i need to buy a new front sprocket as well when you swap the rear one + chain ?
If it has more than 15k miles on it then probably a good idea. It wears the most so would be a shame to wrap a new chain around a worn one.
Oh i'm good then :)
my bike only has 7000 miles. but since the 9000 miles service is coming soon I figured I could change the gearing at the same time ....
Thanks man !
14-42
Makes for a wheelie machine, I’m probably going to put the 15 back on but in the mountains that 14 is sweet.
For those that ain’t donethe math 15-40 2.6 14-42 3 15-42 2.8
I went 15-42 w/ quick changer last weekend, I like the gearing better for general use, fuel consumption seems to have taken a hit but not really enough data on that yet. If increased fuel consumption proves out and I do any touring (realistically not before next year now), I think I'd get an extra chain and a 40T as I like to go as far as possible between fuel stops.
Yea it's pretty giggle inducing... but after a couple years of this silliness and with a bike over 50,000 miles (and planning for a V4 Streetfighter in my not too distant future), I'm going back to 15/40 530 for general use. I AM however keeping a 525 chain/sprocket set at 14/42 that I can swap on when I want to get stupid.
Riding back from going to 14/40. Heavy traffic, stop and go, lots of sub-10mph work, some splitting.
The really slow speed handling seemed easier (sub 5mph). At that awkward ~20-35 splitting speed, it seemed much happier in second than before.
Will advise as I get more commutes under my belt.
Alan
Well, back to stock (from 14/42), bike is now much less likely to get me a ticket (leaning forward in 2nd at WOT now keeps the front wheel planted at DWC 2).
Will be interested to see if my fuel economy recovers.
Also back to 530 chain - 525 is definitely lighter but cost me a LOT of durability (at 14/42 the DID ZVMX chain lasted around 10,000 miles - and it was definitely toast, making that crackling noise and with enough stretch that with the loosest section set correctly it binds badly at the tightest section).
Also not going to keep the 525 sprockets... there was enough visible wear that if I want to have a shenanigans gearing setup I'll just buy another full set and spare masterlinks.
@DaveK
I can appreciate reversing that 14/42 hooligan decision which equate to +5R.
However, (and this is just my personal opinion), I can never go back to 15/40 now that I've tasted the Multi at +2R with 15/42.
@DaveK
So my plan is Streetfighter next spring for troublemaking - Multi (which is now over 50,000 miles) in the less stressful job of touring, maybe the occasional commute.
That is - if I can float it past the wife.
I have 1260 Enduro, which has 15t/43t stock gearing. I'm considering to change rear sprocket to 45t (+2t) as 6th gear is rarely used. This should also improve riding in off-road conditions. I take longer trips on highways aswell. I don't want to start switching between 43t and 45t and there doesn't seem to be 44t sprocket option for Enduro. Has anyone else changed stock gearing on Enduro model? Please share your impressions.
