1 - 8 of 8 Posts
I'm in the process of doing a small refurb and start up on a friends 250 Mototrans and I have some simple questions prior to jumping into it. As there is no manual, which wire connects to the battery. Blue for pos? Black for pos?
Also where do you recommend I go for a kick starter seal as this thing left a 6" puddle overnight. Guess I should have put it on the main stand.
Any outstanding tips and tricks on the singles?
** Thanks to the poster with the link to the Domiracer tach drive seal link!
edit: Nix the tach seal. Doesn't have one. Guess I'll grease it and let it leak.
Kick start seal
Take off the kick lever,measure the seal,or if missing measure kick shaft ect.
It's a common "O" ring seal,then put kick lever back on
Thanks Paul. Sounds like an easy trip to the hardware store.
Any idea on the blue/black battery connection?
It has sat for a couple weeks as the owner has other priorities.
So being a gear head I thought, Ya know,,, I wonder if it is charging.
Nope. Only battery voltage regardless of the revs. Any hints?
Thanks in advance.
clean up the points?
1 - 8 of 8 Posts
