Getting a vibration back through the bars under accelaration, comes on around 6k rpm and tappers off around 9k rpm, seems to be in all gears, most noticable when engine is put under load, any suggestions before I take it back to the shop as I'm not confident of a warranty claim.
Torque your motor mounts . How many miles on it ? I assume it wasn’t vibrating but now it does ? Is it due for a service ? You may need to take it to a dealer to find out if they are aware of vibration issues on your model, or if yours is “special”.
Thanks, it seems an obvious solution to the problem, it wasn't vibrating but after a 250km ride it started, it only has 2400km's and had it's first service 3 months ago and no I don't beleive it to be "special".
