Man it's been awhile since I've last posted...
Anyhow, just picked up the new 950 and was wondering if anyone here has removed the evaporation canister. It is apparently tucked away pretty darn good as I can't seem to locate it.
Any help would be greatly appreciated!
Im going to change the filter back to stock and when i get the tank off ill take a look and let you know if i see it under there, if i do i guess ill just take it off
So its located on the left side of the bike, behind the frame. Not easy to get to. I think you might have to remove the seat, tank and the airbox to get to it. Unless you want to remove the coolant pipes and try to sneak it out the ride of the bike.
