Redbrit
I love my 2014 1200S. I plan on keeping it vs trading in on a V4 since its such a wonderful bike. There are some disadvantages however; it is much harder to find aftermarket goodies for it like Quickshifters that let you downshift/autoblip. The newer version has it OEM but will cost ya. If that's not a necessary item, then there isn't much reason to buy the newer ones. I have purposely not purchased the new Monster as I have added most of what I wanted to this one; plus a ProShift B&B II shifter. The issue is they are having problems getting the shifter to work 'all the time' without triggering check engine lights. they have been good to work with but are struggling. The shifter downshift is butter and works 100% of the time.
Fueling needs some help around the 4-5k rpm range but a RapidBike Evo fixed that. Brake system is the best out there and HP/torque is almost unbeatable unless you buy a new superbike.
The front forks need attention. I sent mine out to be re-valved and the shim stack fixed where the fork adjustments work well. But I only recommend that if you do track days.
Its been a fun bike to customize and I ride it daily. This past winter I did my valve service and it was pretty easy.
Oh, if you wish to change rearsets, its about $900 so depending on how tall you are and if your foot hits the muffler.
Still, I wouldn't look back on this purchase. I have had no issues with the bike at all and I'm at 21k miles.
