1 - 6 of 6 Posts
Hi,
I have a 2013 Multistrada 1200S Touring with the Sachs skyhook suspension.
One leg is leaking and by looking at the workshop manual and the specs i see some differences:
Workshop manual states:
fill with fluid OJ RACING SPECIAL FORK Sae 3.6 at 100 - 14.4 at 40°, quantity 660 cc ± 5 cc in the right-hand leg
fill with fluid OJ RACING SPECIAL FORK Sae 3.6 at 100 at 40° 14.4, quantity 239 cc ± 5 cc in the left-hand leg
Specs say to use:
SHELL Advance Fork 7.5 or Donax TA 170 mm (per leg) (*)
(*) The value refers to the air column between the free surface of the oil and the end of the sleeve, with the
latter fully lowered and without the preload pipe and spring inside the fork leg.
Shell Advance Fork 7.5 has complete different viscosities from the ones stated in the workshop manual.
Also how to fill the oil? Use the specific cc as in workshop manual or measure the 170mm gap as in specs?
This is so confusing...
Also, does anyone have the SKF part number for the correct seals? (I can get directly from SKF instead of Ducati)
Hi,
Specs say to use:
I always fill the oil by measuring the gap. Measure it with the fork leg fully compressed and with the spring and spacer out (per instructions above). 170mm from the top of the fork tube to the top of the oil. Once the oil level is correct, re-install the spacer, spring and cap.
Reactions: shorton
Hi, I just removed both fork legs, MTS 1200S gran turismo 2013, bought the bike a couple of months ago but notice that the front suspensión is very hard, doesn't change depending on the ride mode, so I just notice that the left one (electronic controled) is very hard and y the right one very soft and makes a noticed sound of the spring inside once compresed, and has short travel, doesn't change if I try to adjust it by the top but all the way in or out, no leaks on both of them. Any idea before getting them open?
It will save grief in the long run if you just stick with one brand fluid. I’ve tried matching viscosity and centistoke but there have still been differences.
1 - 6 of 6 Posts
