1 - 2 of 2 Posts
Anyone ever replaced the wiring harness on a similar Multistrada? Dealer gave me a quote of $600 but also suggested it's something I might be able to do myself. Says it's basically just plug and play (or unplug, re-plug and play as the case may be).
Any advice would be greatly appreciated. Thanks!!
There's more than one harness on your bike so I assume you are discussing a major one. I would certainly do it myself; you will have to take most of the body work off and from that point just remove the old harness, take lots of pictures to show how it moves in and around other components and then immediately put the new one on while everything is fresh in your head. You have the shop manual? What's wrong with the original harness?
1 - 2 of 2 Posts
