Hello,
The turn signal switch on my multi is having issues so I figured I would replace it. I was hoping the cable would be near the navigation power plug on the LHS but alas... it appears to be part of a large wire loom that goes under the gas tank.
I have removed all the body parts and can even lift the tank. Just need to disconnect the quick release and vent tubes... but...
The wire looms next to the fuse box and relays on the LHS appear quite connected to the gas tank. I removed a screw from the "sled" the wires appear attached to but it still seems quite attached to the tank.
Anyone have tips here? Seems like if I cut the zip ties the relay box is still connected to this sled (via a rather large rubber grommet) ... but the bottom of the sled seems to just be "inserted" into a hole on the tank. Can't pull it out easily and figured I would ask for help before I give it a good yank and break something.
