Alright, so I have a love hate relationship with my Hyper. I've owned it since it was almost brand new (second owner bought with just under 1k miles, now closing in on 11ks). I'd like to think of myself as a pretty adept rider, riding since I was 14 on and off. I still have not figured this one out and I am reaching out to you guys to see where am I going wrong or maybe I have the wrong expectation?
So to give this some perspective, I come from sports bikes, I currently own a 2015 R1. Understanding the Hyper will never handle the way an R1 does, I do still think something is not right.
So what is my issue? I can never feel my front is hooking. I don't lean as much as I could because I feel my front is pushing as I'm going through my turns, and I fear I'll either run wide onto oncoming traffic or if I lean further the front will fold. I'm using the same tires I use on my R1 and that thing is on rails, I know the tire is not the issue as I can throw anything at it and it will handle it with ownership. Again, I know this can't be the case with the Hyper, but I need to find front end feel. Is this thing just not meant to be leaned? Shouldn't my lean angle be limited by clearance and not by a lack of mechanical grip?
I've set sag at 1/3 of the suspension range on both ends. Still that has not fixed the issue, I have brand new tires on both ends, still pushes, I warm up my tires pretty well before twisty section, still. I increased preload by a few turns on the back, helped a bit but still I don't feel the confidence.
Tires are dunlop Q3. stock Marzocchi forks and Ohlins shock. Any pointers?
