Will a DP ecu for a 2010 1198s work on my 2011 and retain DTC and DQS?
You check the part numbers for the 1198S (2010) and 1198 (2011) ECU's in the parts manuals (downloadable from ducati.com). If you are lucky you may find they are the same part.
Andrew...
Unfortunately it's not the same part due to the DQS. DTC is the same. I had a 2011 S ECU and had to have it reflashed to 2010 specs due to that incompatibility.
-Dave
Thanks for the replies, so looks like my best bet is to have the stock ecu reflashed by someone like DucatiDepot? I will be running a PC-V piggy back but want to get rid of the lambda sensors and exhaust valve codes first.
Yep, or Houston Superbikes/ Desmo Porsche also does it. I have my stock 2010 ECU for sale if you need a virgin one to reflash, I had Termis installed on mine.
-Dave
