1 - 20 of 48 Posts
I'm new to the forum looking at purchasing a 1098 from a private sale. The seller said bike was dropped by previous owner "but has sliders" the damage can be seen in picture. It also looks like the gear shift lever was changed. Current mileage is 8,500. What are somethings I should be looking out for, or questions that should be asked? Thanks in advance
993394
Engine service history. Timing belt history and valve clearance check history. Valve check is due at 7500 miles. It's an expensive service and if it hasn't been done you'll need to have it done when you purchase the bike. Another good one that gets left out is tire wear and age. If the tread looks good check the rubber and the date code on the tires. Tires average $500-700 depending on your choice of tire and mounting and balance. The valve service is usually $1000-1500 depending if any of your valves need adjusting.
Thanks for the reply. How concerned would you be about the drop/ scratched waterpump cover ?
2012 Matte Black SFS
It wasn't dropped. PO was going at speed when it went down. A drop would not scratch the water pump cover. Look for broken tabs on the rear seat. All of the screws should be present and have something to screw into. Also, look for scratches on the mirror, bar end as well.
Service history is important on this one. Follow @Secret Squirrel's advice...
Welcome to the forums though. Occasionally, a SF will pop up for sale here. I think there is still one active listing for a SF...it is super clean too.
Also check that both steering stops on the frame head tube are intact, not busted off from a hard fall, etc..
We all have different thresholds on how clean something is. I'm a clean freak. The one negative about this bike is from the small picture that you have of the engine and lower parts of the bike. Everything is dirty and there are signs of corrosion. Cleanliness also often relates to proper maintenance. Even if it has a good maintenance history for crying out loud take an afternoon and detail the bike from top to bottom before you put it up for sale. The crash damage plus the unclean state of the bike would turn me away. Unless it's really cheap I'd pass. Or if you want a track bike the damage won't matter.
Discussion Starter #7
[/QUOTE
What would you consider to be cheap?
Definitely wasn't dropped while stationary. As previously stated the bike was travelling and did go some distance on the pavement. The pics show the bike is dirty and not really looked after. It is my opinion that if someone can't keep a bike or car clean the odds are timely maintenance wasn't done. Why not start looking to buy a clean bike? These type of bikes are normally immaculate.
Discussion Starter #10
I'm actually looking at two 2010 SF. This one is local lower mileage. The other is about a 8hr drive away looks amazing in pictures miliage is at 13.5k so it's right about due for the its next major service.
My thoughts on the one local are I think, I can get it for a steal given what I see as well as what you all can see in the pictures. As long as there is Nothing catastrophic I can save its life. The seller is asking 6.5k for the one that has been laid down.
6.5K for the one that went down?
Lowball opportunity at 5.5K?
You'll obviously have to spend a bit on parts to get it fully serviced, but you could even do the job yourself if you're up for a challenge.
Then you would be getting a lot of bike (and a lot of fun) for relatively very little.
Discussion Starter #13
Yes 6.5 for the one that went down. If I can it for under 5.5k I'm thinking it would be a steal.
Not really a great deal at all. When you pay to get the bike serviced and purchase the parts that where damaged that will cost maybe $2500. That's not even counting all of the corroded parts and fasteners. If you can do the belts, valve check and shim the valves that changes everything a bit.
Have you considered a Hyper instead? I happen to have one for sale :)
Smut peddler
OP, listen to the reclusive tree rat. That bike is a project for a guy that wants to make chicken salad out of chicken shit. If you don't have the knowledge to tinker and resources to source cheap parts, you'll be unhappy in the long run. When a deal is called to good to be true, it's because it's too good to be true. A tipped over bike isn't a big deal. It happens. But that bike is owned by someone that really don't care all that much aboot it. There's a chance it will end up costing more than a well documented and clean one. You have to ask yourself if you want a project or a bike to enjoy. Only you can answer that.
Reactions: QTip
The condition of the fasteners also indicate minimal care or salty roads and lack of cleaning.
i wouldn’t buy it, period.
I would agreed with what has been shared. These bikes require continual maintenance and deferred maintenance is a big red flag, especially for things as critical as the Desmo system.
If you are interested in a well-kept, fastidiously maintained, and no shady history, mine is for sale here.
Best,
Raza
Best,
Raza
I'd be all over this if it was local...even though I have a motorcycle that I'm completely happy with.
Reactions: RazaSF
Best,
Raza
Now that’s a well cared for bike!
Reactions: RazaSF
1 - 20 of 48 Posts
