Howdy Folks,
I am needing to remove my stock ECU for a re-flash. Can someone please steer me in the right direction for a thread that describes ECU removal on my bike? (FYI, for the smarty-pants type personalities-I have searched).
Thanks Much!!
G
Removal of the electronic control unit (ECU):
Remove the seat.
Disconnect battery negative cable.
Remove the right-hand tank fairing.
Disconnect the wiring connector from the ECU.
Unscrew and remove the retaining bolts.
Remove the ECU from the motorcycle.
Add on....
Just added a step.
Remove the seat.
<insert> Remove the tank cover (2 exposed bolts and 2 more under the gas cap)
