1 - 10 of 10 Posts
Are the pannier mounting bits steel and rubber included? And the top case support brackets?
You need the SPECIAL fasteners for the brackets to bolt up easily, the panniers need the mounting bits the rubber mounts need to be glued on the mounting brackets as they fall off sometimes,
The top case support bracket only needs metric size bolts and a spacer that I made out of rubber brake line hose . I think m5 if I remember.
1 - 10 of 10 Posts
