1 - 7 of 7 Posts
Hi All,
I'm preparing to reassemble the cases on my 1198 and I've got a question regarding the shims used to set the crank preload. When I calculated the preload at the recommended .15mm spec, I discovered that in order to set this exactly I would need to use 2 different sized shims (2.05mm and 2.1mm). I'd like to know if this is an acceptable practice. When I split the cases, both crank shims were the same thickness. I'm not going looser than .15mm, but if I use 2 2.1mm shims, the preload calculates to .20mm, which is actually within the tolerance specified in the service manual. I just need to know whether it's better to use different sized shims or go with slightly higher preload and have them match. Also, if using different sizes, does it matter which side of the crank the thicker one goes on? The manual doesn't weigh in on any of this. Thanks very much,
Ian
Come in Spinner :)
Brad Black will tell you all you need to know about preload.
Better a bit loose than too much as it causes deflection of the crank.
You can use different size shims on either side.
I would er on the larger rather then smaller if push comes to shove.
this brad bloke sounds like a bit of a wanker. i hear he doesn't do coffee either.
i'd not use less than 0.15mm, or more than 0.20. use whatever shims you need to. 0.05mm is not quite that much.
1 - 7 of 7 Posts
