Status
Not open for further replies.
1 - 10 of 10 Posts
15,0xx miles with all maintenance up to date. Belts replaced two weeks ago. Please see detailed maintenance history at the bottom (receipts provided) for a full breakdown. Stored indoors on stands, a charger, and under a cover. Only 800mi. on new Dunlop Q3 tires, brand new brake pads. She's ready to go!
$9000 with everything listed included, or $8700 w/o rear stand or any aftermarket parts that are removable (returned to stock except for exhaust)
CASH ONLY, will not ship. Portland, Oregon. 5O3.347.O557
Accessories:
-Full 70mm Termignoni exhaust system with dedicated air filter and ECU ($3,000+ new)
-Brembo RCS 19 brake master cylinder/lever ($365)
-Rizoma front brake fluid reservoir ($73)
-Rizoma brake reservoir billet mount ($70)
-DP pre-drilled oil filler cap ($39)
-Rizoma billet front sprocket cover ($127)
-3M protection on leading edges of front fairings and 90% of tank & nose
-DP CF tank protector
-DP inspection cover ($47)
-SpeedyMoto pressure plate ($230)
-SpeedyMoto clutch cover ($160)
-SpeedyMoto SS clutch springs ($48)
-SpeedyMoto water pump cover ($290). Bike runs 10° cooler with this!
-SpeedyMoto underbody frame sliders ($150)
-Motovation front fork sliders ($60)
-Cox Racing radiator & chain case guard ($140)
-ZeroGravity "Corsa" dark smoke windscreen ($110)
-DP neoprene race seat ($221)
-Billet keyless gas cap ($100)
-Spiegler 2-into-2 brake lines ($125) with Motul RBF600 racing brake fluid
-BRAND NEW chain & sprockets: DID ZVMX 520 gold chain ($175), quick-change carrier ($195), front sprocket ($39), rear sprocket ($56)
-TST Industries license plate relocate with undertail tidy plug ($136)
-Wired for Deltran BatteryTender
Includes:
-OEM seat
-OEM passenger seat
-OEM passenger pegs
-OEM gas cap
-OEM levers
-OEM clutch assembly (pressure plate+springs+closed clutch cover)
-OEM license plate holder w/turn signals & plate light
-OEM water pump cover
-OEM inspection cover
-Clear ZeroGravity double bubble windscreen
-Brand new, never-installed AFAM 41T ("3-up") rear sprocket for quick-change carrier
-OEM Ducati rear stand
-Pazzo red anodized levers ($200)
-Ducati Red Card (code card) & 2 keys
-Ducati Data Analyzer
Recent maintenance history (receipts provided):
9,545 Belts/valves done (Motocorsa) Feb 13
10,000 New battery installed March 14
10,800 Brake+clutch fluids flushed March 15
12,000 New front forks oil & seals (Motocorsa) May 15
12,600 New rear brake pads (EBC FA266HH) May 15
13,500 Oil+coolant changed, air filter cleaned July 15
14,125 Brembo RCS 19/Spiegler lines Aug 15
14,400 Oil change, oil gauze clean, clutch spring replaced/updated, new chain+sprockets Sept 15
15,000 Belts replaced (Motocorsa). New front brake pads (EBC FA4477HH) Feb 16
Discussion Starter #2
More pics
Clean, clear title in my name. This is the lowest-priced clean titled 1098S I've been able to find online. Selling to fund a Panigale :grin2:
Lovely bike mate, GLWS
What size of Pani are you looking at buying?
Thanks man! I'm pretty set on an 1199S, just trying to decided between red vs. Tricolore. *Maybe* a loaded 899 if it was the right one, definitely not a base 1199 nor a 1299/S...
Discussion Starter #7
Bump! Something evil is on the way and I've only got room for one Italian mistress in the garage >:)
This bike is as clean in person as it looks in photos. Other *motorcycle riders* mistake this for a new Ducati more often than you'd believe!
Discussion Starter #8
Bump for price reduction! Only $8500 takes her home, rear stand included :grin2:
1 - 10 of 10 Posts
Status
