1 - 16 of 16 Posts
Bike has 2705 actual miles no crashes completely clean and clear title with bikes actual mileage in hand. Using her heart for a race bike. So what I'm not keeping is up for sale. Please contact via txt for quickest response 239-four78-eight490
1.frame, rear has typica fender delete Chop, also includes, gauges, keyed ignition cylinder,tank fill cap, "No red key "why I got such a killer deal on an old low mileage s2r" for a fair offer extra I will include the original ecu but with out red key you can not program new keys, you would have to send the ecu to have immoblizer removed, easily done by Houston super bikes, redline, or other's that have the means of reflashing 5am ecu. THe value is in the clean and clear title. No salvage bs! True 2705 mile 2006 S2R. $800 w/o ecu
2. S2r aluminium trellis single sided swing arm $550
3.Oem Upper and lower triple clamp complete with oem bars oem, original bearings, original races $200
4. Speed motto billet upper triple clamp for clip ins 50mm $200
5.2006 S2R oem seat and cowl $260
6.S2R shock and all linkage $100
7. Fuel tank with all fittings other tan fuel pump flange and fill cap $150
8. Fuel pump and flange assembly, flange through wiring has been repaired professionally and is functional $150
9.left rear set with shift lever $80
10.right rear set $80
11.Oem S2R fender $40
12.brembo radial mount 4 piston caliper $80
13.Front forks with axle, need to be serviced $50
14. Kickstand $20
15.S2R front brackets $40
Discussion Starter #2
Having a hard time uploading pictures I can txt what ever picture you want just call or txt, thanks sam
1 - 16 of 16 Posts
