1 - 3 of 3 Posts
So i have been restoring my baby (06 Sport 1000 with a 98 mm bore kit) that I have owned for aprox 4 years now, and after taking everything apart (including all spokes off and polish), got to the motor, which has all the clear coating on the heads showing cracks and fading, so I decided with a help of a very good mechanic friend of mine to fix it.
Took the whole motor out, got the cylinder heads off only to find a big scratch on the horizontal sleeve and piston.
All the parts are from Ducati, so I am trying to find out what parts were used (or what model Ducati were they taken from) so i can rebuild it the right way.
Would appreciate any help.
The back of the piston shows 98-21
Thank you
977397
977396
977394
977395
Looks like you are on your own! If the 98mm bore kit is genuine Ducati, maybe it is simply the pistons and barrels from the Multi/Scrambler 1100 engine? if that was the case then you could find a good used set.
1 - 3 of 3 Posts
