Greetings from Sacramento. So this is what has been happening. My bike as been starting to have some dying out for no reason, and then when I went to start it to go to work this morning, it wouldn't start. I didnt hear the fuel pump kick on when i turned the ignition on. I went thru and check all the wires i have access to and pulled all the fuses to make sure they were good. there is fuel in the tank. The other night riding home form work, it died out on me like it was out of gas, even though i know the gas warning light comes on well before you run out of gas ( as I know first hand how many miles my bike will go before you have to push it) I was close to a gas station so i pushed it and filled it up and it only took about a gallon and a half, but started right up. So today when i got back home form work I was doing research, and trying to trouble shoot, multiple check of connections, pulling fuses, still nothing, I messed about a bit further , now i turn it on and fuel pump goes on and fires right up. on a side note, rode her on sunday 160 miles, and no issues. Any thoughts or inputs would be appreciated.
