Just want to verify that I can use the newer GIVI Panniers on an 02 model as long as I have the GIVI Brackets. Nothing different about the bike itself?
Recently picked up a peach bike with really banged up panniers. I guess they were protecting the bike all these years.
Thank you, Craig
2004 and 2005 ST3/4's had Non Fango side cases, though some late 2005's made have seen the Givi cases. All 2006-2007 have the Givi cases *afaik.* I don't know if the brackets/mounting systems are interchangable.
Mr Leakered
From what has been said, the antlers are interchangeable. You just have to rotate the top mount fitting 180deg depending on which cases you have.
Have a good one.
Life is too short to worry !
Have a good one.
Correct
