Hi guys,
Had the throttle bodies of my Monster (2003 M620ie) replaced last week, according to my mecanic it wasn't reaching the proper voltage (TPS?).
Now it often reaches really high RPM when at idle (worse when engine's hot)... The mechanic says it must be the ECU and he can't do anything. Could you confirm I should try to replace the ECU? On other threads I saw that these aren't symptoms of bad ECU but rather air/vacuum leak. Not sure what to do.
cf. Video of the issue
Thanks in advance!
Thanks in advance!
