Hey there forums!
So I've been reading for the past two days and following instructions other people have posted for solutions to their problems.
However I'm in a rather odd boat.
I just purchased a 2003 Ducati Monster 620. I went to check it out and was able to turn the key get the gauges on (light up green and cycle), was able to get it to start and ran it over to fill up the tires (they were low).
However after I cut the power and filled up the tires, then put in the key and turned it, the cluster didn't light up and all I had was a blinking yellow light.
Come back the next day, I'm able to turn the key and get the gauges to light up and cycle, and kick the starter, but after the first time turning the key again doesn't do anything (still have blinking yellow light).
So I was thinking maybe the battery was dead, trickle charged it all day, put it back in and still nothing.
What seems odd is that this is sometimes working, so any tips on things to check or try would be appreciated or any direction would be amazing.
I've checked the fuses, looked at the connection points (nothing looks bad or dirty) so I'm stuck where I am right now.
