2003 999 Stall issues
795 4
So I just bought a used 2003 999 with 10000 miles on it. It has an upgraded evoltione slipper clutch other than that it is all stock. If I speed up let's say around 40 or faster and I pull in the clutch and slam on the brakes ( to maybe avoid something ) it stalls. That is the only time it ever stalls. It is fine at stop lights and never even sounds like it is going to stall. I dont know if this is a default in the manufacturing or maybe something with this new clutch. Just wanted to see if anyone has had this happen to them.
Thanks
service history?last tuneup?idle speed?theres many threads here on stalling.search and you will likely come to the conclusion that you need the tps-trim-balance looked at
Which you ought not to screw with before adjusting your valve clearances...
It ends up being pretty much a full meal deal to sort out. Might as well do it right from the get-go.
