I have a Termignoni 54mm titanium full exhaust on my 2003 999. Found a 57mm Termignoni/Ducati Performance exhaust pipe "kit". The kit comes w/ everything sans the muffler, instead they give you a new inlet plate to match the larger pipes. I guess you remove your front inlet plate of the muffler and install the new larger diameter holed plate...question is will it fit my present titanium muffler. I would think that all Termignoni mufflers are built on the same jig and just the inlet plate is changed out based on inlet pipe size. The DP catalog says it's made to replace the assymetric Termi slip on exhaust and turn it into a full 57mm exhaust.
Anyone go this route.....
