1 - 2 of 2 Posts
Runs on vertical cylinder only. Pulled the air box to see down each throttle body. On startup the horizontal cylinder gets two squirts of fuel and then stops. I swapped the fuel injectors and the same thing happens again on the horizontal cylinder. When running on the vertical cylinder, when I squirt a little starting fluid in the horizontal cylinder the front cylinder runs for a few seconds. So I have spark and compression but no signal on the horizontal fuel injection other than two squirts at start up. I don’t know where to go from here. The problem was intermittent at first but now it is chronic. Please help. Thx.
Administrator
Hi and welcome to Ducati.ms. We are super happy to have you here.
I will post a copy of your post about the issue you are having in the Sport Touring forum so you have a lot more exposure.
Please fill in your location information in the UserCP Edit Your Details section, that can help if there might be someone local to you give a hand or find new friends to take a ride.
1 - 2 of 2 Posts
