ok here is what has been going on . had all fairings off changing hoses , filled started fine , washed bike to remove any spilt antifreeze and other yuck . ran it let it dry . changed exhaust inserted key fired up turned off replaced all fairings. inserted key turned on key code light flashes 2 times then goes solid. tried few times same thing took key out waited few min inserted key started right up . turned off turned on same thing 2 flashes wont start. Removed all fairings to check connections all good . still same thing 2 flashes no start . then will start . then wont. not sure of the key programming procedure for this bike . possible aerial is damaged ? any way to check
thanks
