2002 Monster S4 rear shock dead.
886 Views 5 Replies 2 Participants Last post by  MightyCalves
Hi, just noticed my rear Sachs shock is completely worn out. Is it anyway to fix it or do I have to replace it.
If the latter, any tips to finding a fitting replacement? Preferably on the cheaper side, like Showa?
1 - 6 of 6 Posts
Monsters after 2002 share the same 305 mm shock that ST frame bikes used, so you could grab one from any 2002 to 2008 Monster or you can also use factory adjustable ST (ST2 for example) shocks. Consider yourself lucky, I spent the last week researching rear shocks and the older Monsters have way fewer options than your bike does. There are probably 10 really good choices on eBay right now for under a hundred bucks
Reactions: 1
Wow, thanks slot!!
Just to be safe, any way to double-check that I have the "latest" version?
Your S4 is the first ST Monster built
Reactions: 1
❤ Thanks!
1 - 6 of 6 Posts
