Hello!
I have a 2002 M750 with the IAW59M ECU. The TPS output isn't programmable for this ECU.
I had it at a bike shop and they adjusted the idle stop screw. I have the Technoresearch tool and its saying 4-4.1 degrees at idle now.
What should I put the set screw at for this bike? The technoresearch doc says 4.5deg, but elsewhere I've read as low as 2.5deg.
Thanks
-Jordan
I did 2.7deg per the link, and was able to tweak the idle mix up (from stock) to get 2.5% CO at exhaust with 1700rpm idle and the bike runs like a top!
Thanks for the link!!
Glad it's running well. You may want to richen it up a bit more. 5% or so might lower the idle to about 1200. Brad's site is full of excellent resources. He posts quite a bit on here and ducatimonsterforum.org. Super helpful guy.
