1 - 19 of 19 Posts
Here goes :)
1098S Ohlins front fork conversion/Triple clamp setup
1098S Brembo Monoblock Calipers w/EBC pads
Speedymoto Gullwing Top triple clamp
Galfer steel braided lines
998R 15mm offset brembo rotors
Forged Mag Marchesini wheels
Carbon fiber air box
Ohlins steering damper
Ohlins rear shock
Yoyodyne rear sets
DP carbon heel guards
DP exhaust guard
DP carbon front and rear fender
Termignoni titanium slip on
Cycle Cat bar risers
Brembo 19x8 brake master cylinder
Brembo RCS16 clutch master
Oberon slave cylinder
Barnette Clutch basket
Barnette Clutch plates
EVR Vented pressure plate
EVR springs and collars
EVR open clutch cover
Shorai battery
Ducati Corse carbon front nose with white number plate
996R Carbon V
Neoprene wrapped seat
wow!
how did you do the fork conversion?
What you need:
1098s/1198s forks, lower triples, and calipers.
15mm offset rotors from a 748R (if you want to run your OEM wheel)
1098s axle and spacers depending on what wheel.
Custom front brake lines.
You can use your stock top clamp and controls from what I believe. I have aftermarket Brembo masters and clip ons.
Dam that bike is still the best ever! Well built clean and beautifully done
I tip my hat.
She really is a fine machine Cali, but for me it's the 10 spoke Marshis that take it to the next level. They compliment the radial calipers nicely.
Forks Speedo & wheel
How did you get your speedo hook up to work or what did you do about your MPH gauge?
Such a nice 998! I have always loved the 998's and man this one blows everything away!
Congrats!
Wow! The most beautiful example of a Tamburini Duc I have seen. Makes mine look like garbage....;)
1 - 19 of 19 Posts
