Not trying to bore you with the same old questions, but searched for a while and couldn't find any info on these:
Just purchased the ST4 from probably the 4th owner. Has carbon fiber pipes with no brand name, also has upgraded air filter and looks as if a chip was swapped,(duct tape over plug on ecu).
Is this probably the DP setup if not any ideas?
ECU says 072U on the chip, and upon start up display says DUCATI ST4
What brand pipe is this?
Will I see any change if replace carbon pipe with stock pipe, just looking for a few less HP and quiet until I feel more comfortable with the bike.
Also has a 14T up front thinking of changing this back to 15T.
Back is also changed but don't recall the numbers right now.
