Hey guys,
I recently went on a trip from Sydney to Melbourne, and on the second day I first noticed some terrible stumbling issues when in either 5th or 6th gear, rolling on from around 3500-4000rpm. At first, I thought it was bad fuel and tried my best to run it down and dilute it with more petrol whenever I had the chance. It then turned into a very bad misfire when getting off from standstill in the CBD, with a very rough idle that would occasionally drop and spike in revs. Babied her to the Melbourne Ducati Dealership who took one look at it and said it was a big end. Being forever skeptical of shitty mechanics in Australia, I elected to ship her home.
Due to fueling up in a small country town, I naturally assumed it was a fuel related problem, and went through all of my fuel delivery system; injectors, filter and pump. Alas, that was not the problem. When doing more testing on the ignition side of the problems, I took both spark plugs out and turned the engine over with the spark plugs on the engine casing, and noticed that every now and then, there would be no spark on both spark plugs even though the engine was turning. The fact that the spark plugs didn't fire on the same rotation of the crankshaft pushed me away from suspecting the coils of failing, as it was very unlikely that they'd both fail together. I'd also switched the leads and plugs around to make sure that the problem was still here. This led me onto checking the timing sensor on the left side of the engine, and although I don't have the correct feeler gauges, I just tried how the engine would run with different air gaps (as the bike originally had two shims put together), but it made no difference and so I replaced timing sensor today, and it still misfires.
I was also pretty confident in replacing the timing sensor would be the solution to the problem, as it states in the Haynes Manual that the sensor should have 680 ohms resistance, and I was measuring just over 900 ohms. However, when I picked up the new sensor from Ducati today and tested it in the car, it was reading around 930 ohms.
I'm starting to claw at every small problem now, as I could only think that the timing sensor being faulty could cause the ECU to not fire the spark plugs, due to not getting the signal. I have also removed everything additional and not necessary on the motorcycle, such as the Power Commander and Healtech Quick Shifter.. Probably about to go through testing all of the engine management relays, and maybe double check my regulator rectifier is working properly when I have more time another day as I could swear that my bike previously had a higher voltage at idle..
Any help or suggestions would be amazing.
Thanks in advance guys!
