I need to remove my impeller to swap into new stator cover. The service manual I have states there is a circlip on the shaft to remove. I don't see one on mine. Did all years/models have them? How do I remove the impeller?
Thanks
Nick
Thanks
Nick
That's odd. Push in on the impeller side, this to expose the circlip. The impeller is spring loaded on the other side of case. Don't lose the clip. Hopefully this works for you.Thanks for the reply. Here is a pic of mine. I can't move the impeller shaft out. I'm afraid to hit it with a mallet, but I don't see any way around it. What a PIA.
Might need another set of hands too.That's odd. Push in on the impeller side, this to expose the circlip. The impeller is spring loaded on the other side of case. Don't lose the clip. Hopefully this works for you.
Sent from my SM-G930V using Tapatalk
In my line of work we call them Jesus clips; When they fly off into oblivion it's "oh Jesus where the hell did that go?!". Then it's off to the parts department and when you ask for the water pump Jesus clip the man knows exactly what your're talking about.Unfortunately, it flew off and I can't find it.
