Okay experts I need your help. I got 2 weeks to fix this issue.
Brought my bike out of storage. changed the oil. rode it around a week or so and went through a tank of gas. It snowed one morning and my bike got a little wet. (not necessarily correlated). later the same day after being wiped off biek wouldn't start.
What I know:
Engine turns, and vertical cylinder is firing(good compression, new spark plug which isnt wet when removed after trying to start meaning fuel is combusting)
***Horizontal cylinder is not firing. spark plug is new. spark plug is sparking. plug is wet when removing from cylinder after trying to start. cylinder also has low enough compression it won't blow my finger off the spark plug hole.
Battery is 1 year old, load tested, holding 12.5 volts. fluid levels good. I also bypassed with car battery (car not running) and same result, engine turning 1 cylinder firing.
Checked timing belt. it is in good shape, was a little loose but no missing teeth or rot.
Replaced gas in tank to make sure no water.
Fuel filter engages when key turns. Already tried spraying some starter fluid down the throttle bodies to see if that would give it some life. still not start.
air filter is fine.
bike won't push start.
both primary and secondary coils for spark plugs are functioning properly for the two cylinders and the fuel injectors read the same resistance across the terminals so they should electronically be fine.
Why wouldn't this bike start? I'm thinking at this point the fuel/air mixture isn't right in the horizontal cylinder to fire cause its getting spark and fuel. not sure if the low compression has to do with it. I am not sure where to go from here.
I have a haynes manual for my bike and I'm not a pro but getting better with the mechanical stuff.
Thanks!
What I know:
air filter is fine.
Thanks!
