2000 748 Gear Problems
714 3
ive noticed recently more and more going from first through neutral to second gear, for some reason it ends up in neutral and is a pain in the ass to get into second. and the other day i was getting on it and it happened again bt this time it was jst lost i had to pull over and go to first then shift to second
Am i doing something wrong or is there a mechanical isse?
Teddy, it sounds like your not preloading the shift lever before you squeeze the clutch. Try putting some upward pressure on the shift lever before you change gears.
Paul
