1 - 2 of 2 Posts
Has anyone installed these filters? Seems like the stock bolts are too long which causes the intake tubes to not tighten down all the way. is this correct?
Thanks
Sent from my Motorcycle iPad app
Hi There, I run the 2 piece MWR filters on my 1098S. I didn't have an issue with the install, but I am running the larger intake tubes on my bike, so not exactly the same scenario as you.
Just clarifying your issue, you feel that the standard bolts are too long? This seems a bit strange as the new filters flange sits between the airbox and the intake, so if anything you would find the standard bolt too short?
1 - 2 of 2 Posts
