Had my 05 999s with about 8k miles at ECS in Middletown NY today. This is one bike I would like to keep long term. I entrusted the first major service to these guys as I wanted to ensure 100% of the bike was gone over and it was done right. Since I did not purchase this bike new, there was 3k miles put on by a previous owner.
While I know ECS has a great reputation, staying at the shop for the day gave me insight to just how much skill and caring these guys put into their work. Steve, Jay and Sean were awesome.
In addition to new belts, oil change & filter, plugs, coolant and brake/clutch fluids they went over every nut & bolt, every square inch. TPS set, idle set and carbs balanced. Loose steering bearing fixed. They ditched the evap can for me too. In checking the bike over they found the clutch basket pretty beat up, friction plates close to gone and a notchy bearing. They also found the termi slips-ons were installed with no exhaust gasket. Everything was fixed on the spot.
Last, and not least, they found a flaking/scored rocker. Also replaced. All rockers were out of spec too. All properly set back to spec, Jay has more patience then any mechanic I know.
While I would rate the wear & problems they found not usual for a bike with such low mileage I am very glad Jay was doing the wrenching VS some other shop. The prices for labor and parts are very fair, the service is simply the best you can get.
So I would encourage all you folks with greater then 6K miles, without having done that service yet, to give ECS a call. Even if everything checks out fine and no shimming is needed or no parts need replacement, it still a very important service and having 100% of all fluids done and the bike gone over end to end will save you money and heartache down the road.
Here are a few pics from today.
