1 - 2 of 2 Posts
I am wanting to adjust tps settings according to BikeBoy post but don't know exactly where to put my DVM probes to read the voltage. Also I assume it is vdc.
you can backprobe the tps connector, don't recall which ones you need to go into, or remove the ecu connector cover and probe in there. 16 and 31 from memory. that's what i generally did.
1 - 2 of 2 Posts
