21 - 38 of 38 Posts
Discussion Starter #21
Wire harness SOLD
Discussion Starter #22
Bump
Discussion Starter #23
Cylinder head studs SOLD.
Discussion Starter #24
revised the list:
  • ignition pickup assembly - $20
  • alternator assembly - $20
  • rear fender, OE plastic, needs refinished (peel paint, wrapped?) - $10
  • ignition relays/coils/bracket assembly - $40
  • intake manifolds - $10
  • crankshaft -$50
  • transmission shafts/gearsets, complete from end to end - $35
  • shift drum, forks, shafts, stopper - $25
  • oil pump - $15
  • side stand - some of the foot has been ground off - $15
  • front axle and threaded insert - 20 mm bearings - $20
  • rear axle adjusters - 17 mm bearings - $25
  • oil strainer - $15
  • primary drive gearset - $30
  • speedo gearbox - 20 mm axle - $15
  • starter solenoid - $15
  • main case oil line fittings - $10
  • crankcase breather catch can - $5
  • exhaust primary pipes w/clamps $25
  • OE sprocket cover $5
  • exhaust primary - head clamps - $5 each
  • rear brake/shifter lever rubber cover - $4
make offers.
Discussion Starter #25
Side stand has had the ground-off portion welded up and re-profiled back to original. The whole thing's been glass beaded bare. Essentially like new (minus paint). $35 plus shipping now.
Discussion Starter #26
Sprocket cover SOLD here.
Discussion Starter #28 (Edited)
Sorry, no. Here's what left as of right now:
  • crankshaft -$50
  • oil pump - $15
  • exhaust primary pipes - $25
As always, offer will be entertained.
Discussion Starter #29
start/run/kill switch (that I didn't realize I had) - SOLD.
Discussion Starter #30
rear brake/shifter lever rubber cover - SOLD
Discussion Starter #31
rear axle - SOLD.
Discussion Starter #32
Rear fender - SOLD.
Discussion Starter #33
Intake manifolds to the aluminum scrap pile.
Discussion Starter #34
Side stand SOLD.
Discussion Starter #35
Bump and reminder that offers are (still) entertained.
Discussion Starter #36 (Edited)
transmission bits SOLD.
so, here's what's left:
  • crankshaft -$50
  • oil pump - $15
Discussion Starter #37
Starter solenoid SOLD.
Can I see a pic of the primary gearset please? Is the primary crank gear splined or is it the tapered with keyway fit?
21 - 38 of 38 Posts
