1 - 20 of 39 Posts
Replacing my original thread that's been closed for some reason.
Everything comes from the same 1999 M750.
Here's what left:
* rear suspension rocker, complete w/ bearing sleeve and hardware - $15
* headlamp bracket - $25
* ignition pickup assembly - $20
* alternator assembly - $20
* oil cooler lines - $15
* rear fender, OE plastic, needs refinished (peel paint, wrapped?) - $10
* ignition relays/coils/bracket assembly - $40
* main wiring harness with one wire spliced (haven't determined which yet) - $50
* OE braided clutch slave hose -$10
* intake manifolds - $10
* transmission shafts/gearsets, complete from end to end - $35
* shift drum, forks, shafts, stopper, and ratchet/pawl - $25
* oil pump - $15
* seat latch - $15
* side stand - some of the foot has been ground off - $15
* front axle and threaded insert - 20 mm bearings - $20
* rear axle adjusters - 17 mm bearings - $25
* oil strainer - $15
* speedo gearbox - 20 mm axle - $15
* starter solenoid - $15
* main case oil line fittings - $10
* crankcase breather catch can - $5
* exhaust primary pipes w/clamps $25
* OE sprocket cover $5
* rear turn signal/brake/plate light wire loom - $15
* exhaust primary - head clamps - $5 each
* rear brake/shifter lever rubber cover - $4
As before, make offers. Shipping at cost and I try my best to pack safely without excess weight.
Discussion Starter #2
oil cooler lines SOLD to a forum member.
snorkels SOLD to a forum member.
Rear turn signal/brake/plate light wire loom SOLD.
magnetic sump plug SOLD.
Discussion Starter #7
~ rear brake switch; excellent condition - $20 shipped in USA.
~ throttle tube; perfect condition - $8 shipped.
as always, make offers.
Discussion Starter #8
I have one front and one rear wheel bearing spacer that are free. Just pay the shipping. Each weighs about 200g each, packed.
The front is an aluminum item for 20 mm axle by 85 mm wide.
Rear is steel, also for 20 mm axle by 78 mm wide.
Discussion Starter #9
shift ratchet and pawl bits SOLD
Discussion Starter #10
Wheel bearing spacers SOLD
Discussion Starter #11
choke/enricher lever and cable SOLD.
Discussion Starter #12
exhaust clamp split rings SOLD.
Discussion Starter #13
clutch and front brake lines SOLD
Discussion Starter #14
rear brake caliper bracket SOLD
Discussion Starter #15
headlamp bracket SOLD
Discussion Starter #16
front wheel SOLD
Discussion Starter #17
seat latch SOLD
Discussion Starter #18
suspension rocker SOLD
Discussion Starter #19
sprocket cover
Discussion Starter #20
revised the list:
* crankshaft -$50
* shift drum, forks, shafts, stopper - $25
* oil pump - $15
* primary drive gearset - $30
make offers.
1 - 20 of 39 Posts
