Have a customer who wants to change from the stock 3 spoke to the Marchesini 5 spoke rear. Anyone perform this conversion?
I have a set of ST4 front forks so the front will be easy. Just wasn't sure how direct the rear was to convert.
Thank you!
the 17mm 5 spoke ss wheel will go straight in. the st or monster 25mm axle 5 spoke wheels are wider on the rh side from memory. might be as easy as a caliper bracket, not sure.
thanks belter. What years would this include? guessing late 90's/early 2000's? fuel injected 900SS?
5 spokes started 2001? 800ssie, 900ssie, 1000ssie.
thanks for the help Belter.
For anyone else following along...I am in search of a 5 spoke marchesini rear wheel off any of those bikes listed above with a 17mm axle
