I am doing the valves on the new to me 1999 900 SS
Good thing too, guy I bought it from said he just did the belts. Both are WAY too lose, 6mm allen goes between the belt and bearing easily, didn't try anything bigger, but it probably would have gone too.
Anyway, valves are a little bit out of Ducati specs. My plan is to use the LT Snyder specs (.004 open, .002 close)
Specs right now are.
Horizontal Intake .002 open, .0025 close
Exh .008 open, .005 Close
Vertical Intake .004 open, .008 Close
Exh 007 Open, .006 Close
My questions are.
Anybody else run as tight a tolerance as Snyder suggests?
I have read about the procedure, and have seen it done with the cam belts on and the cam belts off, any preference? Why?
Belts off makes sense to me as I have also read that after you shim the valves, turn the cam to see if there is any binding, because if you get the closers too tight it will bind the cam as it rotates through.
Thanks in advance for any advice.
P.S. Job is on hold right now waiting for a shim kit to show up.
My questions are.
