1 - 3 of 3 Posts
Bought a set of Ducati replacement fork seals from the dealer. Now what kind of fork oil do you guys/gals recommend? I'm 6'2" roughly 190. And what should the oil levels be in the forks, what are the tolerances?
Thanks
I'd recommend sourcing a manual, but the typical figure I have seen for oil height is 100mm-120mm. I believe any 7.5 weight to 10 weight fork oil would be fine. By the way, hydraulic oil is basically the same stuff, ISO32=10wt, ISO46=15wt. I've also heard of EXCELLENT results with Mobil 1 synthetic ATF and it could probably be argued as superior to the majority of "fork oil" on the market...
1 - 3 of 3 Posts
