BIKE PURCHASE THREAD LINK = https://www.ducati.ms/forums/57-supersport/722869-t-minus-5-hours-buying-96-900cr-today.html
PROLOGUE:
Ok, so I bought the bike, I've had some basic questions about a few basic things answered very graciously by the generous folks of this fantastic membership, and I've made enough decisions about how I am going to move forward with this project to begin building some momentum.
Let It Begin! :smile2:
DE-SHITTING THE STOCK CARBS:
The first thing that requires attention is what to do about the gummed up fuel system. The previous owner put the bike up in Winter of 2018 and forgot to drain the carbs and fuel tank prior to storing the bike. The carbs are gooped and non functional, the fuel tank is rust free, but it has some varnish near the bottom. The previous owner had filled the tank with gas a few weeks ago in hopes fresh fuel would help in diluting some of the poop in the bottom.
Initially I wanted to replace the 23 year old carbs with Keihin FCR41s (the $1400.00 kit which includes new Motion Pro throttle cables, a Motion Pro twist throttle assembly, a K&N air filter, and the bits and nibbles needed to mount the carbs). Rather, I've decided to have the stock carbs rebuilt. I'm using "Gordon" of Custom Carb Services for the carb rebuild. Gordon is one of our members here in Ducati.ms, and he came with very high recommendation by a number of forum members. I'll leave the fresh gasoline in the tank after I've removed it to allow for as much dilution of the crappy cruddy poopy goop at the bottom as possible. Pictures and hand drawn diagrams of the hose connections and routings will be done to assist with reassembly when the carbs are returned to me.
FIRST PURCHASE OF SOME NEW GOODIES MADE:
I've been reading a lot of threads about the 900 CR and various things other 900CR owners have done to improve their bikes, and taken note on things I wish to do. One of those things is replacing the stamped steel guide plates that the rear axle goes through which acts as a wheel alignment guide when adjusting the chain's tension or reinstalling the rear wheel. Apparently, that stock gold colored stamped steel "guide plate" is fonky, wonky, and stinky. It tends to rotate out of position when the axle nut is tightened to specified torque, scratching the piss out of the swingin' arm in the process. The preferred cure for this is to replace the stamped steel guide with a pair of machined aluminum guides made by Moto Techniques and they're called Chain Adjuster Plates.
So it seems those are somewhat difficult to come by these days. I got lucky as hell and located a pair of them on eBay, New Old Stock ("NOS"), and still in their original packaging. The seller had exactly one pair, and no more to be had. I paid $86.98 for the pair, shipped. See attached pics. Before I ordered them, I measured the swingin' arm to make certain these plates would fit. The listed dimensions are (quoting their eBay ad) "Measured about 1 15/16" (1.9375") between the internal sides and 11/16" (0.6875") hole diameter". My swingarm measured 1.925" +/- .. and the axle holes measured at 0.692" +/- ... well within required specs. I hit them with the Paypal number, and snagged them before they were gone!
:yeah: ... :yeah: ... :yeah:
Next to purchase will be clutch, fr brake, rr brake braided stainless steel ... Teflon lined ... plastic coated hydraulic lines ("Galfer"), and a pair of new cam timing belts ("Exact Fit"). I'll be posting pics of teardown and carb removal as I get to that. For now, we're starting with this initial entry into this project photo journal.
I expect this project thread to run well into the Fall of this year (2019) with several (many?) pages... so get comfortable, make some popcorn, poor a pint, and hang on for the ride!
Enough bla bla bla .... I'm hittin the ~SUBMIT NEW THREAD~ button!
L8R SK8RS !!!!
:smile2:
PROLOGUE:
L8R SK8RS !!!!
:smile2:
