Any thing special to think of when buying an old SS?
Jocke
Nope, nothing different really between the 1995 and 1997. Color the engine covers were painted maybe. Fairings are the same as well, only the graphics are different.
As for anything special to think of...if it's cheap, it's gonna cost you later. Check the frame tubes near the steering head closely for cracks. Same for the shock mount on the swing arm. And the welds around the pivot area. Check the tank for rust.
Also check for marks on the swing arm, as well as the counter shaft area for signs of a chain derailing. I'm 2 for 2 on that count as both the Ducatis I bought had a chain derail under a previous owner. Both were damaged to the point of leaking oil from the cracks caused by the derailment.
If you elect to buy, you'll likely want to replace the steering head bearings. Check the fuel filter, pump and suction pick up sock as they were prone to not get serviced. Pretty much it that I can think of right now, other than the normal checks for oil leaks.....sean
